The slow running system controls the first stage of throttle opening, before the main jet comes into play.
You need to remove the float bowl and remove the jets. Blow through all the jets and drilling's. You can use compressed air, or carb cleaner at a push.
I think if you look in the tuning section, you will find some pictures to explain more.
