 Topic: rear static sag setting
Matt@TYGA » Tue Apr 24, 2007 2:03 am
Sean's right. If the spring is correct for your weight then you should always arrive around the same figures.
I run around 5mm static sag and 25mm perched on board. Less static sag can actually help increase straightline acceleration, but get's interesting on the brakes.
