 Topic: rear static sag setting
rgvsean
rgvsean » Fri Apr 27, 2007 10:51 am
Not sure, even a light bike when wet is around 140 making close to 70kg initial weight on the spring assuming a slight front weight bias. 70kg is still quite a lot of weight!
When you add your own weight of say 80-90kg don't forget this is distributed and not ALL on the rear shock so you may only increase the weight on the rear shock by 50-60, LESS than exerted by the bike.
Maybe someone here can do the maths better than me?
http://www.rgv250.co.uk
http://www.thetuningworks.com
