 Topic: Power valve help needed
asprilla
asprilla » Fri May 04, 2007 5:29 am
So its not all plain sailing and i am having major power valve problems! Crying or Very sad
When the ignition is turned on the power valve servo doesnt move at all. When tested with a test light and when shorting the blue/black wire the servo moves so suspect one of the control modules are defect. Either the one under the seat or the one behind the RH rear side panel.
Does anyone know what may be the problem or have some suggestions please? Its an '88 MC18 J2. Cheers!
