Andy's got a good point there.
I've had quite a few NSRs that make a fierce whirring noise. Change the water pump bearing and seals and good to go.
The crank 'should' be ok. If it was a new 'un then you shouldn't be having problems with it, unless it was fitting by monkeys.
