You'll be lucky if it's missing the card and PGMIV as well as the clocks, I hope it was cheap!
Yahoo Japan maybe, keep an eye on this and see what it goes for.
You sometimes see them with an HRC card as well, it's what you want if you want to run a smartcard and get some go out of it, the 030 card is the one, not the 010, the 000 or any other suspect number if your going to use normal pump fuel. You sometimes also see the card on it's own, it's useless to man or beast as they're matched to the PGM.
NSR parts aren't that hard to get, 2nd hand MC28 parts are quite rare though. Honda dealers can get any part that's still available if you supply the part number and they are in the parts manual (most dealers won't have microfiches).
The bodywork would indicate it's a 1994 model.
