 Topic: buying a MC28 with missing keycard - what to look for?
racer38 » Mon Jun 04, 2007 11:43 am
So this is what to do...
You'll need an 030 HRC card. The last one I bought was through tyga-performance.com in Thailand. You'll need to furnish them with the PGM's PIN number. It's printed on a silver sticker located on the back of the PGM IV and you can easily find this by removing the clocks.
Once you have all that Matt or Paul will be able to order you a card......takes about a month I think.
To get it to work with the standard loom requires you to cut and splice a couple of wires. Again the Tyga website shows you how. From memory it's located under the 'MC28 Power Up' section.
Hope that helps and good luck.
