 Topic: Smokey NSR
Steve C
Steve C » Sun Jul 08, 2007 7:49 pm
When it warms up it gets alittle better but if you sit at a light or stop and go it gets smokey again. Pump is not a problem as it is premix I run 32-1 . I have tried a couple of diffrent oils Motul low smoke cuts down on the smoke some. I guess it's just the way it is I don't ride it very often. So maybe the gas and oil settle in the bottom of motor and it takes a while for it to burn away.
