Hi, I am trying to seperate my fork slider from the alloy body ,got the spring and all the damper rod out as well as the oil seal clip. now the fun bit is it a case giving giving a good tug on the slider to pop the seal out or do i need to go into the slider and undo the castlated nut(that requires me to make a special tool to undo) i can see on the inside of the slider before it will come apart. this is a bog standard mc21r fork with no rebound or comp damping many thanks hope you can make sense of this post
cheers Malc
stone chips are the real trophies
