 Topic: exhuast update
nsrmik
mc16 pipes
nsrmik » Tue Aug 07, 2007 9:55 pm
mc18 pipes do fit the 16 but require a tweak to clear the standard brake pedal,you need to put a joggle in the stinger(about 20mm)using a blow torch and pipe bender,it gives you the offset cans look from behind and also the 18 exhausts are a lot less restrictive.
