Hi
I have just made a set of revised rear shock linkage plates reproduced from the MC18 HRC Formula 3 from the technical section, and installed them on my MC18. It has raised it up the rear a fair bit and the suspension is somewhat stiffer. I have tried but failed to attach a photo just to check that I have got them on the correct way.I have the long edge with the 70mm centres on the frame link and swing arm with the pointy end of the plate facing down . Please can you tell me if they are wrong .Thanks[/img]
