 Topic: mc 18 clutch probem
Re: mc 18 clutch probem
Andy » Sat Sep 08, 2007 11:56 pm
tiago wrote:
clutch cable seems ok. Question
It probably isn't though. It sounds like clutch drag. Even if the cable appears OK, if it is worn and stretched, you may not be getting full movement.
It could be worn selector forks, but although they have been known to wear, it's not that common that they will cause neutral selection failure.
