You need to run 296mm Honda rotors (or equiv) which came off most 400 Honda from the time - CBR/VFR/RVF400. I can sell you the set pictured if you need them for $300 AUD.
You can run an original NSR wheel, or you can go to the wider VFR/RVF/RS wheel which has the same brake rotor bolt pattern.
The Magnesium Marchesini wheel in the pictures is very rare - but as with everything, its also for sale if you need it.
tomrux wrote:hey Chris
how much fro the entire front end with trees. I want to fit it to an 18 rk5
Tom
