 Topic: PGM III
StephenRC45 » Mon Oct 08, 2007 10:56 am
If you maintain them well though you dont need to remove the cylinders. You can simply pull the power valve shaft out while holding the valves in place with your fingers.
Clean and then replace. Make sure the piston is at TDC though otherwise they can fall into the cylinder Embarassed
