 Topic: next on shopping list
cgallant
cgallant » Sat Mar 01, 2008 11:41 pm
Most after market caps I found needed to be drilled for the breather.
It's a pretty simple job, just use the smallest drill you got (I think I used the same drill bit I use for safety wire drilling). Just make sure you get the hole in the same area as the breather coming out of the tank.
Charles Gallant
