Well, unless they know someone inside Honda Japan who can get them that's a flat lie, the 030 card is listed as deleted and zero stock. i.e. you cannot order one via normal means.
I'll also wager money they didn't mention getting this card to work will involve taking a soldering iron to your £6.5k bikes loom, a hole saw to the air box, doing something to get round the restriction in the pipes, then require setting up after which you'll have no speedo or oil and neutral warning lights.
