i brought a m18 bottm end and swapped over everything and is now in..
(new pistons, rings, gaskets, cyclinder clean, pins, need rollers etc etc)
put over my sprocket, oil pump, water pump outlet, linked chain.
questions (please!!!)
motor was dry, now is wet clutch, can i use same clutch cable ?
and the clutch leaver under block has little (pull back)
to return the cable back, lol
reeds and vaccum pack things that sit above them, do i need to swap them over too?
is there ANY LINKS TO PICTURES OF ENGINES< without fairing, for reference to where the parts go after,
i forgot some mounting spots, please help thanks guys
THE 300 LIVES AGAIN!
