 Topic: Trick carb question
j911brick
j911brick » Sun Apr 06, 2008 9:24 pm
Not that I think this is the problem, but I did notice something weird.
I bought the HRC reed blocks and stuffers from Tyga. It appears that one is actually 2-3 mm taller than the other. Also, the kit came with two different types of stuffers. One has pointed ends, and the other is blunt and looks like the stock stuffers. The stuffer with the pointed ends will only fit in the shorter reed block (which is the same size as stock). The blunt stiffer fits best in the longer reed block. Is this totally weird and does it matter which reed block goes in which side?
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
