 Topic: Trick carb question
j911brick
j911brick » Sun Apr 06, 2008 10:02 pm
Chester362 wrote:I had an idling problem the same as this on both of my bikes. After cleaning the carbs I balanced them by eye with the spring loaded screw in the centre of the throttle slide shaft. After starting the bike it wasn`t running on one cylinder on idle. I then adjusted the slide balance screw whilst the engine was running, until I got an even idle from both cylinders. You`ll find you have to back off the idle adjuster as you get the non-running side firing. You should be able to achive an even idle this way.
I tried the balance screw and still could not even get the balance close.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
