 Topic: mc21 plug / carb problem
lam.666
lam.666 » Sun May 18, 2008 9:58 am
well finally got the bike started, now im having an idling problem.
if the RC valves are not adjusted properly do they cause poor idle till the motor cuts off?
i've tried adjusting the rev screw but that doesnt work, i might have stuffed that up when i took the carb off so i'll need to check that again
but the RC valves are a thing of concern, following the adjustment steps in the tuning page when i have the switch set to on, and turn the ignition on, RC valves dont move at all... i'll need to check the wiring i guess and see how that goes
but does it cause the motor to idle poorly and die?
