 Topic: Perishing plastics...
Andy » Thu May 29, 2008 9:11 pm
You should be able to loosen off all the fairing mounts and jiggle it around to pretty much clear the pipes. You may still need a small spacer on the bottom right-hand-side (clutch side), but there's usually just enough "adjustment" to clear.
You shouldn't need to bend anything.
