 Topic: Help with Tyga Chambers. cant get a good seal on the Gasket
paul g » Fri May 30, 2008 9:21 pm
keefer wrote:do you put a bit of sealant on the chamber just before you slip it onto quick release part of the barrel ?
I put the sealant on the manifold on the barrell rather than on the chamber so the excess pushes out and not into the exhaust. If that makes sense Confused
