 Topic: Meh NS250R Blown its rear piston, replacements?
2Smoke
2Smoke » Wed Jul 16, 2008 10:31 pm
Andy wrote:You may also consider a slightly thicker base gasket.
I was thinking that, mind you would be worth measuring the squish as all too often I have seen 2mm+ on engines as standard! Could work out ok with the higher pot (although probably not with my luck! Laughing )
