 Topic: Fitting HRC reeds, spacers and stuffers
Andy » Sat Aug 02, 2008 12:54 pm
Just make sure you use a new gasket.
Ensure you remove the inlet manifold bolts evenly and while the motor is cold, as the manifold can distort. Torquw the bolts down as evenly as you can, just like you would a cylinder head.
It's obvious how the parts fit when you take it all apart. No need for pictures! Rectifiers are a direct replacement, as are the reeds. Spacers are just 1mm strips of alloy, and fit between the reeds and stopper plates.
