 Topic: MC21 rear master cylinder won't build pressure
chappyr1
chappyr1 » Tue Aug 05, 2008 8:33 am
I had same problem with new pads. It looked like the piston was pushed so far back into the housing it wouldnt allow fluid past it. Did as someone else suggested, took it off the bike, removed the pads and put a piece of thinner rubber in there, bled the system, the replaced the pads.
