racer38 wrote:
I found side to side rocking better than front to back when mixing in the gas tank...............
Is that because of dodgy fork seals Tom?!
t3racing's comment about not leaving fuel in the tank is not really applicable to the NSR, and I am sure he would've been using something like A747 or HTX (and probably AVGAS too) with the TZ which is indeed susceptible to separation over time, but synthetic based 2-stroke (modern consumer) oils have a special formula to help prevent it.
Just remember that if you go premix on the road, that it's much simpler to fill up in multiples of 1ltr. I love having the pump and just sticking in £10 or whatever I want each time. It doesn't matter if that tenner is 8.40 litres of Super or 8.93 litres of 95RON, as the pump's mixing it! When you have to measure the correct ratio of oil, you don't have that casual luxuary, and 1/2 a litre is quite a difference!
