 Topic: Mc28 Chain tensioning
cgallant
cgallant » Thu Feb 03, 2005 10:18 pm
on the end of the swing arm is a pinch bolt. Untighten that pinch bolt. you will see a toothed type plate. Use a spaner type wrench (that you adjust your rear shock with), and turn that disk. It will either pull the tire back, or push it forward. Adjust as normal, and tighten down the pinch bolts.
Thanks,
Charles Gallant
