So the strip show starts......
I don't know where to start this story...other than I wanted to know what was under the carbs
Carbs are 39mm PWK Two stroke specfic but I question if they are too big for the cc.
Under the carbs the plates were glued together with one plate holding the screws for the carbs. The next plate held the screws going into the plate that held the screws that bolted to the crankcase. Well after all that chessy fab work it just gets better......
Next I pulled the reed cages....one carbon reed three stock reeds. Then I noticed only one of the steel pedals was attached.
Why would someone do this??
The rearsets were trash...bent,shift shaft bend,pegs rashed.
I left the shop
On to the next adventure why my coolant looks a little milky....
1993 MC21 SP
