 Topic: GPS Blank Plug??????
fontyyy » Sun Oct 12, 2008 5:27 pm
Surely this is just a plug to go where the neutral sensor is?
This is something quite fancy on a '21 as the PGM needs to know what gear the bikes in.
On an '18 and '28 it's just a wire, I snipped mine off on the race bike Wink
If that's the case it's of use if you're doing a tidy job on a race bike and don't need a GPS.
Unplug the neutral wire on a stock carded '28 and it won't run in gear (will it Tom?).
It looks the same for a normal loom and PGMIII'd '21 (as the neutral wire goes back to the PGM), on an '18 it just means the neutral light stays on.
