 Topic: Clutch Housing Seal
Andy » Sun Nov 23, 2008 3:47 pm
Er... no different to fitting any other seal. Prise the old ones out, and press the new ones in! Confused
Use a socket with the same OD as the seal as a drift for the the kickstart seal to gently tap it back into place (you don't want to directly hit the new seal), and use the old clutch seal on top of the new one for the same reason.
