Sorry Brett, we all got side tracked.
You you are right.
Shorter ratio will make it accelerate harder with less top end available. Same thing as running a short diff ratio in a car, or low range in a 4wd, mehcanical reduction results in more torque produced at the wheels. The engine however, is still only making the same power and torque.
