 Topic: Blocking pin
sr71gator
sr71gator » Mon Jan 12, 2009 4:05 am
Thanks! You have to understand some of this is confusing because I have more than just the HRC kit - I've got extra bits somehow; i.e. two 'y' pipes, 4 emulsion tubes, etc. So I've got these lovely rubber caps that fit over the oil feed tubes on the carbs, negating the need for the blocking pins.
Or I just peel out the brass tubes and put in the pins.
