 Topic: need some advice
StephenRC45 » Sun Feb 01, 2009 11:12 am
The gear box oil pump runs off the back of the clutch basket.
Not good its missing. You will need to strip the box down and make sure its ok. I think I have a few spares of them kicking around though.
There should also be 2 needle roller bearings in the clutch hub. That won't of been doing anything any good if one of them was missing. I'm sure I have a few of them kicking around too!
Yes there should be a ball bearing on the end of the clutch shaft, under the top hat.
There are also dowls behind the transmission plate. If I recall 2. These locate the plate into the crank cases. It might well be one of them.
