 Topic: mc18 carbs
Andy » Sat Feb 07, 2009 7:43 pm
TA21's could be used, but why? Are you looking for a quick performance upgrade? If you are, you won't find it by fitting MC21 carbs.
Pull the black/blue wire behind the rear lights and drill a couple of 20mm holes in the airbox, and an R2/4J will make around 62hp if it's fresh. If you want more than that you need to start getting inside the motor.
