 Topic: NSR150SP Cylinder & Piston, Type A, B, C
Matt@TYGA » Mon Feb 21, 2005 6:04 am
If you use the recommended cylinder and piston combination then the performance between the three sizes available would be so small you couldn't measure it. if you have to buy a new cylinder and piston then order whichever is available.
From what I've seem, the B is the most common fitment to the stock machine.
