Hey Max. If you have added some 2t to your gas tank, you have leaned out the fuel/air ratio. How much depends on the quantity of fuel in the tank that you started with.
The additional oil will also make it difficult to get a proper plug reading. Try again with unmixed fuel in your tank. ( if you are sure your oil pump is working). A new set of plugs will also make it easier to see the color.
