Hi guys,
I'ved tried searching, but cannot find the stock setting values anywhere.
My '92 SP MC21 is understeering in corners. I'd like to check to see if the previous owner has fiddled with the settings. At this stage, I am just trying to start from an standardised reference point and check the easy, obvious and cheap things before I start servicing/taking things apart.
Other factors may be the mismatched tyres (a Bridgestone BT90f 110/70 and Michelin Pilot 150/60) both about 1/3rd worn; tweaked chassis geometry - fork tops are flush with top clamp; worn head or swingarm bearings etc; tired shock; the rider (75kg's); or a combination of any of the above.
Thanks
Scott
