 Topic: TYGA PIPES
Jim
Jim » Sat Mar 05, 2005 3:17 am
From experience, if you are running an aftermarket shock that increases ride height, that will make the chamber rub against the swingarm. Regardless, you can try grinding about 1 mm off the back side of rubber mounted insert in the frame (where the bolt mounts the chamber to the frame). This will push the chamber outboard a bit and give more clearance. Got this directly from Paul at Tyga. Hope that helps.
-Jim
-Jim
'93 MC21
