 Topic: New MC28 owner needing some simple tuning answers
nxrsr20
nxrsr20 » Sat Apr 25, 2009 3:50 am
If you look at the right hand side of the engine, do you see a plastic cover with perforations that allows you to see the clutch plates? Does it rattle like crazy wihle the bike is running and you've pulled the clutch in? If the answer to the plastic cover is yes, then you have a dry clutch Smile
If you have a solid metal cover, then it is a wet clutch. If it rattles like crazy, I'd be running for the hills!
Motul 710 is synthetic. Oil choice is much of a muchness as long as you choose a good quality oil and consistently use it, rather than chopping and changing brands all the time.
