 Topic: oil pumps
Max szeged
Max szeged » Tue May 12, 2009 5:30 pm
Someone said before that the best way to know if its working is to run premix and take the tubes from the oil pump into a catch box or bag (one for each tube). Ride it as you usualy do and see if you end up with oil in the box or bags after a ride. remember to block the openings to the carburator!! or it will rev like a nut!
They are hell to bleed as well so better run a tank of premix once you re-fit the tube to the carburator.
feel the wind
