Hay all. I jest finished converting my mc21 wet clutch to a dry clutch. also changed the bearings on the gear plate seal. After i put the whole thing together i noticed the gear box movement is very stiff. before I put the gear assembly into the engine i checked for free play and smoothness and It all looked ok. ounce I put gearbox in and torqued it down i found it to be stiff and hard to get moving. Shifting is the same where i only got it in 1 neutral and 2nd gear. I got the engine started but only in neutral. I'm thinking it needs like a break in procedure. Maybe running it in first gear might get it to loosen up. But before i do that want to get you guys input first.
Also jest got the frame powdercoated grey. will post pic when done.
thanks in advance.
