The NGK caps are a direct replacement for the Honda ones. The lower Honda one has a nice angle on it though, to point the HT lead back towards the frame spar where the coil is mounted. The NGK cap can leave the HT lead a little stretched if you trim it back at all (like you should) when you replace the cap.
I run the red NGK cap on the top, but an HRC "shorty" plug and cap on the bottom.
