 Topic: MC21 uneven spark
StephenRC45 » Mon Jun 08, 2009 7:53 pm
If you are using the genuine HRC heads then you can use the stock plugs. If you're using the '28 rear head swap as in the later SP manual then you will need to use the shorter plugs.
Honda part numbers for the shorty plugs are 31930-ND5-003 and 30700-ND5-751 for the caps
