 Topic: locking collar on rear shock
Deon
Deon » Thu Jul 02, 2009 5:19 am
The shock must come off first. I would use an oxy/acetylene torch rather than a butane one. The heat must be concentrated and applied to the lock nuts only. Keep the heat away from the spring. If you heat the top nut quickly, it will expand without transferring too much heat into the shock itself. Two C spanners and some muscle and you should be done. Good luck!
