 Topic: Rebuilding/Cleaning carbs tutorial
dld
dld » Sat Jul 04, 2009 10:54 am
So I got around to pulling the carbs off the bike, really not so bad, a bunch of dried up rust that cleaned out easily. The gaskets were crusty dried chips, so I got my local shop to order me some new ones for a hefty cost.
At the base of the float bowl, the air mixture screw was seized and had rust filled in the hole. So i assume I should now set the screw to the default location,which is 13.7mm, found here
http://tech.nsr-world.com/nsr/nsr-all/carb-settings/
How do i measure this?
reading the figures on my jets, im seeing 145 on the MJ, and 38 n the SJ. Not stock?
DSC_4531-web
Looking at what came in the bag, can someone help label what the medium sized circular rings are for.
DSC_4536-web
Should I be worried about the slightly misaligned needle below.
DSC_4524-web
