Neal wrote:Howzit , go I have a 16 front srocket if you want to try it !At Phakisa , you want to come onto the backstraight in 4th changing into 5th , 6th should rev out as you hit the apex of the right hander . You hold it flat out in 6 th gear and the two corners bcome one . Watch out for the ripples on the exit of the corner , have fun !Neal
16 sounds like a good fix since I might not be able to get rears cut before the weekend.
I'll take your word on hitting that 6th gear flat out
If you want a proper 2 stroke get an RGV.
