Better crankcase filling I've heard. The mixture has a straight run into the underside of the piston, so when it sucks, more gets sucked in, meaning slightly higher compression in that cylinder, hence some people putting thicker base gaskets on the front cylinder when you run it closer to the edge
The Chopster
