 Topic: Servo Motor
Andy » Fri Aug 28, 2009 1:33 pm
montsta56 wrote:
is it a straight forward procedure replacing the TPS as i have a spare ??
THanks
It's straightforward if you have the Torx bit to undo the retaining plate screw and a multimeter to check the setting once the replacement TPS is fitted.
Fine adjustment of the TPS can be the difference between 30hp and 60hp!
