I was having problems with lean running so i decided to do an airleak test.
Before i fill the left inlet manifold with air i sprayed some carb spray in the right inlet on the reeds and then blanked it with a cap.
After that i filled the left hole with air and after a while i pulled the cap from the right hole and saw lots of bubbles on the reeds.
I believe its a very easy way to see if air passes trought halves.
So i am holding the crank in my hands like a baby (a heavy one)
am wondering what to do...
The best is to fit a new one i know but nowadays with all that knowledge and with all that bearings maybe the situation has changed.
Is it possible to succesfully rebuilt the crank without sideffects?
What about rods etc?
Has anyone rebuilted with no problems?
Any responce and infos would be great and much appreciated!
Thanks..
