 Topic: MC18 R2J needle/needleholder alternatives
Andy » Fri Oct 23, 2009 12:48 pm
You can use MC21 HRC needles, although the profiles aren't perfect for the R2J. You will need the HRC emulsion tubes too, and the HRC needle holders.
Quite how you'll get on with the air correction is another matter. It will probably take a lot of fiddling to get it to run cleanly from idle to redline.
